  • 4 Replies
  • 2263 Views
Merengue
All of my cameras (5) have been making flickering images when at play back.  I have noticed this since yesterday 6/11/2019 at about 5pm.  Now this moring, 6/12/2019 9:30a.m. are still doing the same.  I have reset the base station but nothing yet.  Any help? Thank you in advance!
does it do the same if the video is downloaded and played direct?
Merengue
The flickering happened when the clip was being played.  However, I did not try to download it because I played it from the pc and not from the cell phone.  When I download from the pc, the name of file, date and time is hidden in multiple numbers, which makes it hard for me to locate unless I rename the file.  But, no matter what, I tried rebooting the pc twice and the Arlo base a couple of times and for some reason now is all back to normal.  Thanks for your response TomMac.
An easy way to find the downloaded video is to open the download folder and change the sort option from filename to date modified/created. The video should then be the top item.
Merengue
Thanks for the advice jguerdat (Guru).  Will do so!
