Multiple Audible Notifications for Single Event
Uninstall and reinstall the app....
Ronny2,
Is this a request or is this something you are experiencing? Could you provide more details on this topic?
James:
I have that problem also. See my post https://community.netgear.com/t5/Arlo-Pro/bd-p/en-arlo-pro
Not a solution to multiple audible notifications for single event. Only happening on my S8+ running Oreo, not on wife's iOS device. Everything else is solid.
JoeCymru,
I was able to review your support ticket on this issue. I will escalate for further investigation.
Uninstall and reinstall again and you can have four. The number seems limitless and is only bound by one's own desire to continue the uninstall / reinstall process. I gleefully got my S8+ up to thirteen to prove a point to myself.
- Clear the cache and data from the app Setting>apps>arlo>storage
- Uninstall the app (on your phone not at PlayStore)
- Go to Settings>cloud and accounts>back up and restore
- Turn off automatic restore under Google
- Back up your data to your Samsung account
- Restore your data from your Samsung account (back up and restore only takes a few minutes)
- Power cycle your phone for good measure (off / on, not restart)
- Go to PlayStore and download Arlo app
Hopefully you are back to one, not up to four. If it does not work, go through the above procedure again but make sure that Google back up is also done when Arlo is gone from your device.
Just wondering if creating a whole new account for Arlo would help.. Prolly' a PIA but just an idea.. But before doing so make sure you clear all related cache and delete App.. Not sure if simply deleting the App would auto clear the cache.. I don't have a device to test it...
Unnecessary and potentially could complicate other things to create new account. That would not help at all. The issue seems to be with the Arlo app and Oreo update. Google did some notification enhancements going to Android 8.X.X that Arlo is not totally compatible with. I have only found one other instance of this problem, that being Microsoft Outlook for Android. On the MS boards there were complaints and MS fixed it. Arlo has not ... as of yet. The 2.5.2 app release on June 4 still has the bug. I tested it. Then got rid of it as I outlined above. It has nothing to do with accounts or the Arlo firmware. It started as Oreo began rolling out. It is a problem with the Arlo app and the device OS. The 2.5.2 app update fixed a few other minor things, but is still buggy. People may also have some issue with geofencing when their carriers update their OS to a version of 8.
The engineering team is currently investigating this issue. I will provide an update when I have more information.
Read versions of fixes upthread. Without one of the offered procedures, each time you uninstall and reinstall the app in Android, you will add a "ding" or whatever notification sound you use. This is a known issue and there are multiple threads created on it, but the work arounds involve you settings under Cloud and Accounts>backup and restore> Google.
This issue is still under investigation by the engineering team. I will provide an update as soon as I know more.
There is a difference between getting multiple audible notifications from a single event and the new update which gives individual icons for each event rather than only one updated icon (and notification read out) as was in the past. I believe this started on the 8th. If you have multiple audible notifications, solutions are up thread. If you are getting multiple individual icons and read outs for each event that is a new thing (though not a necessarily smart move on the developers part for those owners who have very active cameras). I believe the latter was introduced to help with smart thumbnails in the notifivations for those who subscribe. That's a guess.
In response to JoeCymru, I am getting multiple notifications from each single event (two at the moment). I've tried the up-thread solution from Alphaphase to turn off notification sound and setting the sound to 'none'. This silences the notifications, but they're still coming in in droves and I have to dismiss them all. I'm not going to reinstall the app because it seems that will lead to even more notifications, and I'm certainly not going to wipe my phone. These are not solutions. There are a number of other community threads complaining about the same issue. Can't we get a REAL fix that doesn't involve deleting Google backups, wiping the phone, reintalling the app, etc.?
I have stopped the multiple audibles twice. The Android app is still buggy, evn after the recent update.
Alternate 1:
- Delete the app from your phone, on your phone. Do not delete it using the PlayStore.
- Settings> Cloud and accounts>Backup and Restore
- Turn off Back up my data under Google
- Turn off Automatic restore under Google
- Power cycle your phone to insure you clear cache (turn off and on, rather than restart)
- In my case,(s8+, Oreo) to make sure, under Backup and restore, I also back up my data and restore it using my Samsung account with Arlo gone (only takes a few minutes and nothing is lost).
Go to Playstore and load Arlo.
Alternate 2:
All above but: Put a few hours in between the above and reloading, toinsure that Google auto updates have run with Arlo gone. This may not be necessary, depending on the last time it ran.
I agree that the issue needs permanent fixing. Without a process each uninstall and reinstall will give you an additional notification which will drive one insane if they have done multiple uninstalls trying to fix it.
