  • 2 Replies
  • 1056 Views
Shulbok
I've moved and can't get my system set up again. Tried the setup through the app and can't get it to work. Is there a phone number for customer support?
dcfox1
Unless you have a subscription Arlo's new policy will not give phone support. You can check the support options in the support setting in the App and if you have a subscription a phone number will be there and at least chat or e-mail options W/O a sub.  I don't get the new policy but that is the way it is now.
Simply moving the system doesn't require setting it back up. In most cases, just plug the base into the router and turn it on. When you get 3 green LEDs, you're reconnected. Of course, the batteries in the cameras may be dead if you didn't remove them during the move. When the cameras can't connect to the base, they're wear down the batteries trying to reconnect.
