Motion sensor sensitivity
What is the camera looking for as far as motion goes? what does the sensitivity setting control? Does it control the size of a moving object that triggers it? or is it a distancefrom camera? I have tried changing the setting and nothing really changes. If I understood how the motion sensor works then maybe I could help my self out.
thanks
When I try to change the sensitivity for motion detection it doesn't seem to be saving. I'll change the sensitivity and then back out and when I go back in, the sensitivity is back to 50%.
Am I doing something wrong?
Its been awhile since ive used either to make changes, but there is one if you look around.
Make sure you're editing your modes since the Motion Detection Test setting won't save - it's just to let you experiment. WHen editing your modes, use the Back link at the top left for the app or the Edit Rule link for the web page. Save is there.
I had the same issue - the ux within the test area could be improved and allow you to set the sentivity following the test.
To set the sensitivity you need to go to select mode>rules>select the camera to edit>motion is detected and adjust the level. After this return to the previous page (edit rule) and scroll to the bottom and save the chnages. do this for each camera you have.
