Motion sensor not always working
What sensitivity setting have you got the camera set for?
PIR motion sensors work best when the subject moves across the field of view. Objects moving towards or away from the camera are far more difficult to pick up. With this, you may need to reconsider the position of your camera to get the optimal response. Alternatively, you could do what I've done and have a second camera at 90 degrees to the first camera and have each camera trigger themselves to record as well as triggering each other. This requires a custom recording mode and additional rules.
Also, the Arlo Pro has a much better motion sensor than the original Arlo Wirefree.
My recommendation is to set the sensitivity at 100. Then each time you get a false alert (notification / recording) within 30 minutes of a previous one, turn the sensitivity down by 1. Eventually you'll get to a point where the sensitivity setting is great for capturing what you want captured and there are minimal false alerts. I generally find it's in the low 90s but YMMV depending on the location. The added bonus of having it fine tuned is that your batteries also last longer. Try to avoid having a lot of trees of bushes that sway in the wind in the frame if you can
I will try setting the sensitivity and see if that helps. Thanks for the help Steve.
Yup. You shouldn't get false alerts when your sensitivity is as low as the stock standard 80. Hopefully you'll find a higher level that will get them coming and going consistently
You can insert images using the share feature when viewing a video from your library or by using the Insert image icon just above the text box when replying here (looks like a mountain with the sun/moon). You can also host it from an Internet site like Dropbox, etc. and post the link here.
