Motion detection lag with hardwired Arlo Pro (not.2)
  • 1 Reply
  • 1225 Views
winterminute
I'm looking at the Arlo Pro and plan to hard wire it. I heard that there was severe motion detection with wireless leading to the "look back" in Pro2. If I hardwire a pro, what kind of lag can I expect when detecting motion?
Also, can I configure how sensitive the camera should be to motion? I'm coming from BlueIris which gives me a ton of control, too much actually, but would still like some options.
The lag of a Pro, even when AC powered, is the same - ~2-3 seconds is the best you can expect. The Pro 2 cameras enable the 3 second look-back when AC powered.
Motion sensitivity is set in your modes and rules. It defaults to 80% and can be adjusted per camera. Just be sure to save.
