Everything is working OK for the most part, but when I check a recorded 10-second (default) video from a recorded motion activity (for which I was properly notified), the activity is already over ... I'm thinking maybe it started recording too late after the activity was completed ? I got 10 seconds of my backyard recorded but with nothing going on. What's up with that ? Thx.
80, the default. I cranked up the recording time to 30 seconds from 10, and tested the exact same motion and it got most of it then, with about a 2 second delay from wake-from-sleep.
You may have bad cameras if you're recording in an empty room. Of course, make sure that IR bouncing off walls from sunlight isn't causing the issue - maybe stick them in a dark room to verify.
Delayed recording can also be a symptom of weak WiFi between the camera and base. Just something to check.
