Hello there,
I was wondering in terms of motion detection, is there any future planned updates to give you the ability to draw out a detection area? That way you could have a view of the road at the end of the driveway, but it wouldn't trigger until an object entered say the driveway, as an example.
From my understanding now, the camera will record upon detection of anything within its field of view, please do correct me if I am wrong as I am trying to research as much as possible before investing in this system.
any pictures you could show me of this solution? I guess its a great low tech interm thing but having such a programmable area for detection would be pretty great.
Here's two different cameras - you'll have to wait for them to be approved. Ignore the cobwebs - they're gone now 🙂 :
thanks for that. I will have to look into implementing something of that nature also I guess.
The motion detection has a max range so I highly doubt it would pick up traffic at the end of a driveway if mounted on a house unless the driveway is pretty short. If it does, you could always dial down the sensitivity and that could function as a defining of a detection distance.
My motion detector is set to 1% and I get messages every 2 minutes from both cameras. One is aimed at an empty front porch and one is aimed at the street 75 ft away. When it was on 80% it easily saw every car but missed the main part of the driving and only caugt the last 1/3 of the recording.
Now that it is on 1%, it just alerts every 2 minutes. and the other one also.
I am a novice.
