Modes only shows "base station" under devices
  • 15 Replies
  • 8438 Views
  • 4 Likes
  • 6 In Conversation
dustin2788
For Arlo pro, when I press the mode button on the bottom, it only shows "base station" under devices. The manuel says it will show your cameras there. I want to set up different modes for different cameras. Any help welcome. Thanks.
15 REPLIES 15
dustin2788
After clicking on MODE, click on the BASE icon, the cameras should show up on the right side
dustin2788
When I click mode it then says "my devices". It shows the base unit, and to the right it says "armed". If I click on the base unit it then gives me the options of "armed, disarmed, schedule, or geofencing. Is that normal? When I click on settings- my devices, it then shows the made unit on top, then the base unit again with a bell next to it, then my cameras after that. I'm not sure about that either. Thanks for your response.
if you click MODE you should see like this orvery similar;
If you click on SETTINGS, it's this or very similar
dustin2788
Clicking mode I only see "base station". No cameras listed. That's my problem. On the pic you can see what modes different cameras are in. When I go to settings and see my devices I have 2 base stations listed. Not sure why. Thanks for the help.
Can't tell you why 2 base stations are showing but first things first. When you go to the Mode tab, you have to select your base since it's possible to have multiple bases.
dustin2788
When I click "mode" it shows me "base station". I click on that and it then gives me the option of armed, disarmed etc. it never shows me cameras. In the Instructuons I should see cameras that I can change each mode independently. Thanks for the help.
Each mode (Armed, for instance) has one or more camera rules in it.  Edit Armed (pencil or > icon to the right) and see all your cameras and their settings. Rather than modifying Armed, which is the default and is useful for troubleshooting), create your own custom modes so the cameras do exactly what you want.  Create multiple modes so some cameras are on, some are off (any cameras without a rule are disarmed) so you can then schedule them appropriately.
Bfassler752
I have the same problem. Did you ever figure this out?
Which "same problem"? What have you tried? Have you read this thread and the FAQs?
Bfassler752
When I click on modes, I can only see the base station, not each separate camera. On the Devices section, I can see the 3 cameras. I cannot click on the base station on the modes page.
Bfassler752
As noted, try selecting your base.  This is needed since you may have multiple bases or Q cameras, each of which is set up idividually.
Penny123
I have the same problem - when I select mode it show the same as other posters: just the base unit, no cameras, and the base unit can't be 'selected' - clicking on it does nothing.  The last time I logged on (yesterday) I was able to see my cameras listed below the base, and I could individually change their modes - don't know what happened between yesteady & todayMode screen snapshot.png
Penny123,
Clicking the ">" next to the the desired modes will allow you to edit the rules for each camera.
