  • 4218 Views
Topdown645
I have the Android app that used to work, I now constantly try the link you send me via email. My new S7 will not, ever, even once load anything regarding triggered shots or my account. I only get the bird with flapping wings. How frustrating!
Try and un-install and re-install the app
Topdown645
Thank you, I'll try that...
Now, my more important issue is when I get notifications sent to my email and there's a link to see the 10 second clip that triggered the notification...it won't load, period...the birds wings keep moving so it's trying to load but it never does, believe me I've waited many minutes, double-checked my settings, etc. & I am confident I have excellent reception, good WiFi, etc.
It's like there's too much info you're trying to send me, other sites are pretty much instantaneous. So, how do I fix this? Going thru the app is nice for certain things but there's too many steps in doing that every time. Thx
I don't know why you have an issue... I use an S7/os 7.0 and have no issue.
Someting is causing it for you it seems.
Does an email on a PC work fine ?
As to the last part, other have requested a wiget that would go directly into like live screen or similar, but it hasn;t happened yet
