Mic is back for IOS
  • 2 Replies
  • 4600 Views
Jeep4x4Rider
I hope this helps with others who had problems with the loss of intercom capability; I.e missing mic icon: I took the following actions this afternoon: 1. Restarted Arlo Base Station 2. After reboot, logged out of app by going to settings then profile and logout 3. Rebooted iPhone and then logged back into Arlo Pro and mic was. Ack and functioning as normal. I don't know if all these steps are required or if the order in which I performed them made a difference. Good luck.
JPC
Prodigy
Prodigy
Yes, a recent update on the iOS App came through.. Re-starting the system like you did or Delete App & Re-download or loggin out your  account and restarting the App are some of the options to make it work..
JPC
Prodigy
Prodigy
YES... delete the app and re-install has made the mic come back
