Lost button for opening camera and replace battery
  • 1 Reply
  • 2565 Views
moblej123
Somehow, the button you push down to open the camera and replace the battery, has gone missing on one of my arlo pro cameras. You can still get the camera open by pushing down inside the opening (where the button used to be) with a ballpoint pen, but has anyone else had this problem, and does anyone know if there is a replacement part available for purchase? A search seems to have turned up nothing. Thank you.
There are no parts available for purchase. You'd have to maybe buy a dead camera for parts.
In the meantime, if the camera is outdoors, I'd put a piece of weatherproof tape over that opening.
