I am trying to display live video in full screen using the Arlo app on a Samsung Tab 2 10.1. When I touch the arrows in right hand corner of screen, it switches to full screen but shows only a dark blank screen.
What OS version? Have you restarted the tablet and reinstalled the app?
Hi, I have just re-started and re-installed the Arlo app. It's running Android 4.2.2
No idea then. It may be either an OS issue (even though I believe your OS version is supported) or possibly a hardware limtation. Open a case with support here to see if they have an answer.
