Why is my Arlo Pro only recording 1 out of the 4 cameras into my library?
I tried to reset the filter to " All" but I only get an "any" option
If able, try on a PC at https://arlo.netgear.com/
They have a Reset on the filter...tho ANY means all cameras when on the filter
First try a MANUAL record from each camera to verify the video is added to the Library
If not, then check the software version on the cameras and base as this can cause an issue.
Also do a simple reboot of the base via the power button and then retest when it all comes back online.
