  • 4 Replies
  • 3139 Views
Newk430
I subscribe to the Premier plan and have noticed that during day my camera activates multiple times but after a few hours most of videos are no longer available in the library and there are no videos available for any previous days.
Newk430
Thanks so much for your help. I feel like an idiot know. Just proves the simplest explanation is usually the most accurate. My girlfriend has been deleting them without my knowledge to save space because she didn’t know we paid for 30days of storage. Thanks ton.
brh
@Newk430
Check your filtering in the library. I am wondering if you have a filter set so that you are not able to view them.
Brian
Newk430
Thanks Brian. I checked the filters and I do not have any set.
brh
@Newk430
This is truly wierd as all the videos are stored on Arlo's servers and should be available for 30 days. Are you on a shared system? I believe that someone has access to your account and is deleting the videos. You should probably change the password immediately and don't give it to anyone. If that doesn't work then you might need to contact Support and possibly they could see from their end what is going on.
Brian
Newk430
