LMC4030 compatible with a VMB4540 smart hub?
Are the LMC4030 cameras compatible with a VMB4540 smart hub?
There are no LMCxxxx cameras.
If you mean the VML4030 (Arlo Go), then the answer is "no". If you mean the VMC4030 (Arlo Pro), then the answer is "yes".
The compatibility list is here:
