  • 2 Replies
  • 4697 Views
VABlitz
Ever since the last firmware update for my cameras they have only been triggering when something is within 5 feet of them. The motion sensitivity is at 80% (No Change) on all of them. I have tried the 100% setting from work, but shadows from the trees seem to be triggering it. Is there a way to roll back the firmware update to see if that latest update was the cause of this? I noticed one of the fixes was PIR false triggers and I have a feeling that is probably the cause of this.
Not that I'm aware of
VABlitz,
Has anything changed with your network? (Base station has moved, slower internet, added more wireless devices potentially causing interference).
Some things you can try:
-Reboot the base station (using the on-off button), reboot he camera (remove and reinsert battery)
-Temporarily relocate the camera to see if the behavior is the same in a new location
-Be sure the battery is fully charged
