Is it worth it to go the Arlo Pro Base Station for $40?
I am going to add 2 Arlo Pro cameras to my current system of regular Arlo cameras. I can buy the 2 Arlo Pro cameras for $380 or purchase the New base station and 2 Arlo Pro cameras for $240. Is it worth the additional $40?
It's up to you, but I'd say get the new base if you can swing it because of the added features.
Thanks. Yes, I did mean $420. Are you saying that I would be able to use both bases to get better coverage? Do the two bases sync/"talk" to each other?
Remember your Arlo subscription is primarily based on the number of active cameras you run. Set up the new base under the same Netgear username you're currently using and you should see them all together in the app.
Not really... as mentioned , there is no limit to number of bases... AND it's the only real way to expand your coverage of an area with cameras...
BUT each base is sort of it's own domain. Meaning, each base must be armed and can run it's own schedule, the camera and bases all appear in the app/web prgm but are separate when it comes to commands/rules/modes
Mine that the bases don't have to be in the same location tho either...so it can be a plus or minus.
.In my case, I have a base now at one end of the home and one in the center... I can arm the center base which covers the outside cameras and den/living areas only. The far end base covers mostly the bedrooms which i don't use when home of course...so it adds another level to modes if use correctly ( ie you can use multi schedules with two bases, something not possible with one base )
When out of the home I have to arm both bases to cover in and out... not really a pain, but there is an extra step.
