  • 2 Replies
  • 3251 Views
  • 2 Likes
SallyC
I just purchased my cameras from Costco and was under the impression that the Arlo Pro was 720p but I just read in the manual "The default video resolution is 720P. You can change this setting to a higher or lower resolution"   I found the slider and moved it from Optimized to Best Video but I can't find anywhere what change that actually makes.  Does anyone know?  Thanks.
Best is 720p, Optimized is 640p and Battery Saving is 320p.
SallyC
Thank you, jguerdat.  That's really helpful.
