- 2
Invert issue driving me up a wall. There's one camera that I get a better angle by keeping it upside down but when I put it to the invert option and save, everything seems to be okay, then once I view the recording it's upside down. I used the search bar but couldn't come up with anything that resolves this issue. There was a lot of posts so I know it's an issue. Any body experiencing said issue"? The posts I read weren't very current.
27 REPLIES 27
Chrome or IE on desktop. Chrome on mobile. App on mobile.
Invert does not stick on any of them, for many users. Pro, and non-pro. This shouldn't be too hard to find and fix, one would think.
Since you're the one with the issue, I would start thinking that it may have somethinng to do with the system itself. If possible, swap at the store.
Wow. I'm far from the only one.
- 2
