Hi
I've read about the 5v vs 9v discussion, but I haven't seen what INPUT voltage the USB-charger has.
- Base station:
- In:110V OR 220V.
- Out: 12V, 1.5A
- USB-charger:
- In: ???
- Out: 5V@???A / 9V@???A
I'm getting one from USA and will bring it to Europe.It's easy to get a 12V 1.5A power adaptor that will fit 220V and our wallplug, but does the USB-charger work at 100-240V? If yes, a plug converter is readily accessible. If not, can I use a Samsung 5V 2.0A / 9V 1.67A?
In: 100-240VAC, 50-60Hz, 0.3A
Out: 5VDC, 1.8A, or 9VDC, 1.1A
