Incompatible Charger Message For Arlo Pros
  • 1 Reply
  • 1515 Views
poconobob
I have 3 arlo cameras 1 uses 4 non rechargeable batteries, the other 2 are rechargeable.  I cycled thru about 6 chargings on both cameras then started getting the "Incompatible Charger Message" For Arlo Pros. I am down  to one working camera (the battery powered unit). I tried swapping the batteries, chargers and cables so far nothing seems to help. I am open to suggestions.
When you swapped batteries, did the problem stay with the battery or the camera? In any event, open a case with support here for faulty hardware.
