Incompatible Charger Error
This past weekend I went to charge my Arlo Pro which I bought in June this year. Was very pleased with the product until now. When charging I am met with the message ‘incompatible charger detected’ even though I am using the usb lead supplied in the box. I can see this is a well reported issue and I’ve trued rebooting the base unit and my router, swapped the batteries round with my other two cameras and also tried different usb chargers but still get the same message. I suspect it’s a faulty lead, does anyone else have the same issue?
I have two ARLO go cameras that I have outside on light poles. I plugged them in to an AC outlet using the ARLO supplied cords. Both worked for a while then stopped and I got the same or similar error message as you did. In both cases the camera stopped working until I removed the charging cords. I have no solutions for you though.
Are you using the charger that was supplied in the box?
Charger needs to be QC compatible with dual voltage output.
Hi Matt1975,
Have you tried contacting customer support regarding this? I have attached the link here for you
Matt
