If I buy another system (2 base stations), can I get 10 cameras from the same internet connection?
  • 2 Replies
  • 1741 Views
dmike
Arlo pro allows 5 cameras... If I buy another system (so that I have 2 bases), can I get 10 cams from the same internet connection?
Yes, you can run more than 10 cameras on the same connection as long as you have the bandwidth.
The issue you will have is the Basic level account allows only a total of 5 cameras.
You can use two accounts ( diff email/passwords ) or upgrade to a paid account
dmike
Thanks for the reply, TomMac
