Câmeras can not sync. Blue led blinks slowly several seconds than turns to amber and blinks fast. Tried several times and with different camera units unsuccessfully
Did you claim the base first? If so, try removing everything in Settings, My Devices and start fresh. Use the Add Device button in the Devices tab to claim the base. Sync the cameras. Be sure to only briefly press the base sync button - don't hold it.
Most common mistake is holding the base sync button ( old info says hold for two secs )
Only a quick press and then the camera sync button
I tried again but it still did not work. Once I have 3 Wi-Fi nets, next step will be to desconnect 2 of them to avoid interference and start all from the begunning again..
Now it succeeded!
