  • 1 Reply
  • 1445 Views
Retired_Member
Not applicable
I have one Device (base station) with 4 cameras connected to it.
The cameras are placed both indoors and outdoors.
What I've been searching for is a way to have the indoor cameras set to GeoFence, so after I come home they are not constantly going off and sending me notifications but later at night I can have them "turned on".
At the same time I would like to have the outdoor cameras active all of the time (not subject to the GeoFence rule).
It looks like I can't do this with one Device?  So do I need to purchase a second Device and split the cameras between the two ?
JessicaP
Hi MG1967,
What you can try doing is using custom modes and schedule mode to incorporate it with Geofencing. You can read about these modes and how to set it up here:
Once you create these modes, you can implement them on "Home" or "Away" on Geofencing.
