How to change volume for siren on iOS app?
  • 1 Reply
  • 1602 Views
Dr_Henning
Hi,
Is there a way to change the volume settings on the siren at the IOS app, i can find the activate siren button
by pressing the shield, but there is no edit mode.. i suppose that if i press activate siren, it starts to make a
sound, but in former versions of the app there was a possibilty to turn it up and down..!
Base: Firmware 1.12.0.1_27940
Camera: Firmware 1.092.0.19_26228
Regards Dr_Henning
Only in your modes and rules can the volume be changed. I think you used to be able to set the volume when manually activating the siren but not now.
