  • 2 Replies
  • 2327 Views
buzzbeekeeper
Does anyone have suggestions on changing the Motion Detection Threshold below 50% to prevent passing cars in the street from triggering the video recording start?
Thanks, All Ideas/Suggestions Welcomed.
A.
brh
Is it possible to lower the angle of the camera or reposition it so that the street is not affecting the operation?
Brian
Reaiming the cameras is the optimal solution but may not be possible in all cases, at least not completely.
To change the sensitivity, use the Mode tab, select your base and edit your modes (Armed by default). All settings are in there - make changes and be sure to save. There are FAQs here that have complete directions and can help you set up custom modes for complete control.
