One of the cameras I had would not automatically record or send anything to the library. I could pull the camera up and I can see the camera operate. It would not send anything to the library. I sync this device multiple times with out any success to send videos to the library. I removed this device only to find out I should not have. How can you add more devices once you have your system set up?
If you removed the camera from the system profile, all you have to do is resync it like you originally did.
