How often do you need to clean the Arlo Pro lens when mounted outside?
I was first thinking of mounting the Arlo Pro up high using scaffolding/ladder to reduce the chance of theft.
But then I thought, how often do I need to wipe the lens. I will use the Arlo Pro skin.
How often do you need to wipe your lens if mounted outside?
No snow near me.
Thanks.
If you have no snow, probably not often if at all.
I've had an Arlo up for over a year now.... had to clean/wipe it off twice only due to a spider web which was causing false triggers.
So after last nights big rain storm, my camera is perfect during the day. So only at night was it having some issues with the rain probably due to the IR reflection of the rain drops on the camera or something. So i would say you really shouldn't have to clean the lens at all like TomMac said.
