I don't want the siren going off whenever the camera is triggered to record
Go to Mode and select your rule. Select the edit pen and then scroll down to Turn siren ON. If it's not checked, your siren won't sound.
I don't see what you call a "rule". Nor can I find a switch to turn the Siren on/off. I would like to access and activate it remotely on my Iphone. So far no successs at doing this. any other help you can offer would be appreciated.
Modes and rules are found in the Mode tab. Check the FAQs for much more info.
If all you want to do is remotely activate the siren, it's on the Devices tab along with the cameras. There's a button to turn the siren on and off.
How do I ensure siren is always off?
edit your mode, pick camera, toggle off the siren for that camera... repeat for each camera
