How do I increase the microphone volume on my Arlo Pro camera?
I recenly tried to speak with someone on my front porch using the microphone on my Arlo pro camera, and to find that the volume was extremely weak...nearly unhearable. Is there a way to increase the volume so someone can actually hear you? Thanks.
The app volume has limitations due to the device used. A computer typically has additional settings for the mic to increase gain while a phone doesn't. Make sure volume is turned up in any setting you have.
The Arlo pro is not worth having. I cannot hear it and the people on the front porch can barely hear it. I will be returning it to Best Buy next week
Ewyoung,
Which client are you using (iOS, Android, web client)? Make sure all of your volume settings are turned up (on both the device and within the app/web client). Are you still experiencing the same issue?
