How do I add my new Arlo Pro system to my existing Arlo Wire-Free system?
I have the Arlo pro that has the two-way communication, how does it work and how do you turn it on. Also do you have an add-on device to up- grade it to Arlo pro plus that has the audio device.
The Mic and Speaker must be toggled on in the settings to function.
Once in live view if you click on the mic, a push to talk button appears...hold it and speak.
There is no update for Arlo to change it to an PRO model.
Also, you must use the Pro base since the other base doesn't have the ability, as Tom states.
