How To Delete Multiple Recordings
How do you delete multiple recordings at one time?
In web, you can click on more than one... in apps, it's usu ahold on one and it turns ( green border ) and then select more.
Either way it;s per day only.
**** BUT, I strongly recommend deletes NOT be done... there is no limit on storage and they auto delete on your service level days... if you find you deleted and want it back it's gone! ***
