  • 5 Replies
  • 4116 Views
rodzulu
Still no resolution to the ability to arm siren from made setting with just button selection
Now have to delete Arlo then add device to arm siren
Went from one step to five steps just to arm sirens
Great Work Netgear
5 REPLIES 5
Need details - that doesn't make sense. Do you mean manually activating the alarm or using it in a mode?
ShayneS
Hi rodzulu,
There is a drop down tab with the option to alarm the siren. Is this what you are looking for?
rodzulu
No
I know where the tab is
The option to arm the siren in mode setting is gone
Ther is no longer a button labeled ( turn siren on ) only a do nothing button
Before I was able to arm the siren by activating the ( turn siren on ) button to be triggered by by motions and audio arming
ShayneS
rodzulu,
If you would like to set the siren to a mode, Tap Mode > Select Base Station > Edit The Desired Mode > Edit Rule > Add Device > Alarms/Base Station > Edit Alarm. I have provided a link to an Article regarding setting up a mode with the siren.
How do I create a rule that includes a siren trigger?
rodzulu
I know that procedure seems to be only solution Arlo can offer but is not the solution I am looking for
