How Do I Know If My Battery Is Charging
How can I tell that my battery is charging? Usually when things are charging, I light goes on or flashes...with Arlo...nothing...
Is it charging?
On the Devices screen look at the battery icon for each camera. If you see something that looks like a lightning bolt in the battery icon, it is charging. If the battery icon is solid, it is not charging.
Brian
And the percentage should change in the camera settings section.
