How Do I Block Out Unwanted Motion?
My neighbor keeps setting the motion off on one of my cameras. Is there a way to block out his part of the property? On my work cctv cameras I can do this. I just don’t see that option on the Arlo items. Thanks.
To do that you need to use AC power or subscribe to Smart. Your work cameras are constantly powered and the battery-operated Arlos need the same. Smart bypasses the need but uses server-side processing so the camera still records - you just don't know it other than battery usage.
