Pls. help me to setup custom mode as below requiremnt, I read so many artciles but still not able to figure it out.
I have three Cams
CAM A
CAM B
CAM C
My Requirments are.
CAM A - 24 hrs motion and Audio Detection Recording
CAM B - motion and Audio Detection Recording with sound from 11 PM to 6 AM
CAM C - motion and Audio Detection Recording from 11 PM to 6 AM
I know how to create modes and rules, just need help to setup the schedule so that I dont have to manully Arm/Disarm.
You need 2 custom modes (you could use the default Armed mode for one but it would be better to create your own for full control).
Mode 1 - add rules for all cameras with appropriate settings for each one.
Mode 2 - add rule for only Cam A with appropriate settings.
Now add them to the schedule to automate the process. Mode 1 would be added from 12:00AM to 6:00AM and then again from 11PM to 11:59PM. Mode 2 would be scheduled between 6:01AM to 10:59PM. Be sure to select the Schedule as the active mode when done.
Thank you so much. Never though it will so simple,
I have set it up , will share my experience after few days.
