Help with camera triggering siren
Ive read all the help on setting up the alarm so your camera triggers it but its not possible for some reason.Under the base station rules each camera does not have a box to check for the alarm.Im really stumped any one know what or how i need to adjust it?
Remember, the "alarm" on Pro cameras appears as a separate device.
My Arlo Pro is off line at the moment, but isn't there an alarm option there in the "add device" settings for each mode?
There is support for Arlo stuff, including manuals, at the end of this link:
>>> Arlo | Support | Default<<<
Or visit the document library:
Arlo - Security Cameras and Systems
Pick your model and get the manual.
See the section Add a Rule That Includes a Siren Trigger.
Just another user
