  • 18 Replies
  • 7349 Views
  • 2 Likes
dukecam
The previous version had on/off times on the schedule - this one only has ON!
18 REPLIES 18
When you want to disarm the cameras, change the mode to standby (with an automation).
If you give details on
  • how many cameras you have
  • when you want them on and off
then we can give more tailored advice.
dukecam
10 Cameras
  • On 11PM - record video overnight - all cameras
  • Off 6AM - standby - everything off - we are home for the day
  • On 8PM - record video and send notifications on perimeter
  • On 11PM - overnight again
The previous APP allowed me to set schedules by camera - this new version is only Away/Home/Standby
@dukecam wrote:
10 Cameras
So 8 pm- 11 pm is some cameras, but not all?
You can manage three combinations of cameras.
  • Arm Away already should arm all cameras
  • Standby already should disarm all cameras.
So the first step is to configure Arm Home to arm only the perimeter cameras.  If a rule for a camera is not included in a mode, then that camera is automatically disarmed when you use that mode.
After you get that set up and tested, post back and we can move on the the schedule automations you need.
Actually that depended on how your cameras were connected.  You'd have one schedule for every directly connected camera.  But if you used a base station, you'd have one schedule per base.
That said, the lack of custom modes was a big miss on Arlo's part.  Also the automations are too complicated (and can't still don't support all the use cases).  Inyour specific case, you will need to disable the schedule manually when you go away (and want to keep the cameras armed 24x7)
dukecam
ok thank you - will set for tonight
dukecam
Than you for this. I tried everything - disengaged and re-set all modes, schedules and automations but it is still not working on the timed schedules. This is so disappointing from a company that was A1 excellent in my books this time last year.
Hey Arlo: Fire the design team that created this new application. Obviously not tested with paying customers (me - 7 years and 10 cameras). Check out the forums and your reviews. Not good.
Please post screenshots of your automations.  The guidance I gave you does work, so there must be something not quite right.
dukecam
ok - will be right back - thank you again for your help
dukecam
Hi Stephen,
Here is what I have: I just want overnight and daytime - no geo fencing needed. On at 11:30PM to ARM everything and off at 5:30AM to go into STANDBY
Screen shots:
1. The Modes I see to begin
2. Arm Away - I have all cameras set to record motion (only)
3. Arm Away camera example -  "House facing back gate" Set to record a Video only - no other actions
4. I have only 2  schedules ...  Overnight system on @11:30PM and Home system standby (off) at 5:30AM
5. Overnight I want to record a video set to all cameras
6. Daytime - set for 5:30AM then...1.jpg2.jpg3.jpg4.jpg5.jpg6.jpg7.jpg
7. Changed mode to Standby ...
@dukecam wrote:
Hi Stephen,
Screen shots:
So you did not follow my advice.
Once again, you have only three modes to work with.  If you want geofencing, the "Arm Away" has to be dedicated to when you are actually away.  So that means you can only switch between "Arm Home" and "Standby" in your schedule.
In your "Overnight" automation,  you  telling the system to record videos at 11:30 in your schedule automation.  That only makes one recording for each camera at that time.  It DOES NOT arm the cameras.  You are also telling the system to only make those recording when the system is in "Arm Away" mode.  What you need to do instead is switch to either "Arm Home" or "Standby" when the system is NOT in "Arm Away" mode.
Your "Home" mode correctly just changes to "Standby".  But you are telling to always switch to "Standby" at 5:30 am, even when you are away.
I suggest deleting all of this, and trying again to follow my advice.
dukecam
Stephen you rock  - success - I have the overnight mode set - on at 11 - off at 5AM. I haven't tried the Geo-fencing for fear I'll mess up the settings. I honestly do not understand why Arlo made this so complex.
I really appreciate your help. (Hey Arlo, you, not so much).
But I guess business is good - prices increasing ...
https://www.theverge.com/2025/1/4/24335628/arlo-secure-plus-subscription-price-increase-ai-features-...
Great!  I'm glad I could help.
circle_0-1
genau dieses Problem habe ich auch!
3 Kameras 05.00PM "Abwesenheit aktivieren" ( für jede Kamera einzeln einen Zeitplan eingegeben) funktioniert  seit 2 Tagen.
Um 09.00h AM sollen die 3 Kameras sich automatisch wieder ausschalten = Standby..
Habe 1 Zeitplan hierfür eingegeben, mit Eintragen aller 3 Kameras.
Nach 09.00hAM laufen die Kameras immer noch.   Nichts ist mit automatischer Abschaltung.
Bitte um schnellstmögliche Hilfe für die korrekte Einstellung des/der Zeitpläne.
What you should have is two schedule automations.  One to switch to "Arm Home" at 5 pm, and one to switch to "Standby" at 9 am.  Both of these automations should be enabled in "Arm Home" and "Standby", and both should be disabled in "Arm Away".
To arm the cameras 24x7, you just manually switch to "Arm Away" when you leave, and manually switch to either "Arm Home" or "Standby" when you return.  Alternatively, you can create Arrive and Leave automations - let me know if you want to do that.
You cannot schedule cameras independently if you have the "Feed" interface.  So if you have one automation for each camera, you should delete those automations and use the approach I outlined above.
circle_0-1
Hallo StephenB, Können Sie mir bitte helfen für eine 24x7  Automatisierung :  über Nacht
3 Kameras einschalten um 17.00h ; diese 3 Kameras ausschalten am nächsten Tag um 09.00h.
Meine Versuchseinstellungen funktionieren nicht, daher habe ich ALLE gelöscht.
Frage dazu: Muss man für jede Kamera einzeln eine Automatisierung erstellen,
oder können alle drei Kameras über eine Automatisierung ein- und ausgeschaltet werden?
Ich kann leider nicht täglich regelmässig  "einfach manuell"  schalten.
Vielen Dank für Ihre Unterstützung.
@circle_0-1  wrote:
Hello StephenB, Can you please help me for a 24x7 automation :  overnight
Turn on 3 cameras at 5pm; turn off these 3 cameras the next day at 9am.
My trial settings aren't working so I deleted ALL of them.
Question: Do you have to create an automation for each camera individually,
or can all three cameras be turned on and off via automation ?
Unfortunately, I ca n't just switch gears manually on a regular basis every day  .
Thank you for your support.
What you need to do first is set up the three modes correctly.
  • Arm Away and Arm Home should arm all three cameras
  • Standby should disarm all three cameras (meaning that there should be no rules in the standby mode).
The rules section in this article should help you with that setup.
The next step is to set up the schedule automations. As I said above, you need two of these - one that switches to Arm Home mode at night, and one that switches to Standby in the morning. There are NO other actions needed in these automations. They ONLY need to switch the mode. Here are two screen shots that you can use as a guide. The times aren't the same as what you want, but you should match everything else.
Pay particular attention to the enable list - right under the automation name. This needs to be set to "Arm Home, Standby" as shown in the screenshots.
At this point, the schedule will run automatically as long as the system is placed in Arm Home or Standby mode. If you manually put the system in Arm Away, the cameras will be armed 24x7 until you manually change the mode to Arm Home or Standby.
It is also possible to add geofencing, to automatically change the mode to Arm Away when you leave, and to change it back to Standby (or perhaps Arm Home) when you return. Several users have reported problems with the geofencing not triggering when they leave or arrive, so you can't fully depend on the automatic geofencing.
Another factor is that when you return, the automation will switch into a specific mode (and not immediately follow your schedule). For instance, if the arrive automation switches to Standby, then you will need to manually switch to Arm Home if you arrive after 9 pm. If you forget, the cameras would remain disarmed until 9 pm the following evening.
If you want to set up geofencing, you can use these screenshots as a guide:
Again, be careful with the enable lists. "Arrive" needs to be set so it only runs when the system is in "Arm Away" mode. "Leave" can be enabled in all modes.
circle_0-1
Hallo Stephen B, weil mein Provider netcologne.de einen Totalausfall hatte, machte ich meiner Basisstation VMB 4000r3    einen RESET.
Anschließend Neuinstallation meiner 3 Kameras: ARLO Pro 3 VMC4040P = 1 Stück     //      ARLO Pro VMC 4030 = 2 Stück.
Die Neuinstallation von VMC4040P     und       1 Stück VMC 4030 Art. NR. 4XH27372AFFB4 waren erfolgreich.
Die zweite VMC4030 Art NR. 4XH27379AD604 lässt sich nicht installieren, da die Basisstation sie nicht erkennt / findet.
Auch nach einem RESET dieser Kamera AD604 erkannte die Basisstation sie NICHT.
Eine Synchronisation Basisstation vs. Kamera zeigt erfolgreich an, blaue LED blinkt schnell.
Ich habe ALLE Möglichkeiten für "Gerät hinzufügen" versucht:  Durchsuchen Ultra / Profi / wesentlich / Pro3Flutlicht/ARLO.
Selbst per my.arlo.com/#/lookingArlo/4XH27379AD604/VMC4030      hatte kein Erfolg.
Eine Installation nur über WLAN geht nicht, da ich nicht permanent WLAN eingeschaltet lasse.
Kontakt mit Fritz Box an arlo-Basisstation über Netzwerkkabel RJ45.
Welche Chance habe ich noch "Gerät hinzufügen".... oder ist die Kamera ... AD604 etwa defekt?
Der Akku ist vollgeladen, blaue LED leuchtet konstant bei Stromanschluss.
Bitte um Ihre Unterstützung. Vielen Dank.  Freundliche Grüße aus Köln
@circle_0-1 wrote:
Hallo Stephen B, weil mein Provider netcologne.de einen Totalausfall hatte, machte ich meiner Basisstation VMB 4000r3    einen RESET.  ...
Some others have reported this too - unfortunately I don't know of a solution.
I am tagging the mods - @BrookeN , @JamesC , @ShayneS - in case they can help.
circle_0-1
Hallo, ich habe es gestern noch "auf gut Glück" über die App versucht. Es hat problemlos geklappt.
Die App hat meine zweite VMC4030 sofort erkannt.  Zufall???  Oder Problem aus der aktuellen Firmware?
Danke und schöne Grüße aus Köln
