Has anyone attached the mounts with 3M 2 sided tape?
  • 2 Replies
  • 5647 Views
Brilis
Hey guys,
Just purchased an Arlo Pro 4 camera system, all hooked up to my wi-fi, all cameras working as intended. As I get ready to mount them, as anyone used any other method besides the single screw that comes with the system?
I did not want to put holes in my siding. Anyone have any luck with say 2 sided tape or maybe a type of silicone?
Thanks.
Brian
pcuser12345
u can do it just be aware as long dosnt espose to water it will weakend the expose to water rain put under the roof there no water on it u shoold be fine
I've done it with 3m double side tape from the auto store ( trim tape ) for the original Arlo ( pros a bit heavier )... it is outside and I've seen no problem in a year... stuck to aluminum
