Hard To Hardwire Camera When Using Security Mount
Anyone else hardwire their Arlo Pro when using the security mount? Seems like a design flaw that when using a security mount, that you cannot easily access the chrging port in order to hardwire.
May be true, but there are many mounts out there that will fit if need be, as the 1/4-20 threaded hole is standard.
Which security mount?
Just another user
