  • 3377 Views
  • 3 Likes
New2ArloPro
Video and live stream worked on all platforms for first month.   NOW:  works fine on Android S5 Galaxy, works fine on Surface Pro 4.  On HP Pavillion Laptop (win8.1, Shockwave and Flash) ...some videos palyback ok, some are green video with audio.  Realtime is green.  Is a special player required?  Thank you all!
New2ArloPro
Thank you Steve and Tom.  I was having IE11 issue. wiht Flash as you suspected.  I uninstalled Shockwave and Flash from Control Panel and reloaded.  Now works fine.  Thank you.
steve_t
Master Master
The same videos play fine on your phone and SP4 but play green on the HP? Maybe uninstall and reinstall Flash on the HP
Also you can test a downloaded file on the same device... that doesn't use flash... to see if flash is not properly working
New2ArloPro
