Getting 2 notifications for every motion detected. How can I fix this?
  • 1923 Views
TriggerJob
I am getting 2 notifications for every motion detected. How can I fix this?
JessicaP
Hey @TriggerJob,
What device and OS version for the phone are you using?
TriggerJob
I am using android. It was working fine for the longest time. For some reason I stopped getting notifications. I changed a setting in Arlo and I started getting them again, but now double.
pc2k17
Hero
Hero
First try force stop, then clear the arlo app storage cache and data. Go back into arlo app and pick your sound again. If it's still two then try this.....
  • Uninstall the Arlo app
  • Go into Android "Settings", then "Cloud and Accounts", then "Backup and restore"
  • Down on the bottom there’s a toggle that’s says "Automatic restore", toggle that off
  • Next, tap on "Google Account" (in the same menu)
  • And at the top there’s a toggle that says, "Back up to Google Drive", toggle that off
  • It will give you a warning that you are about to delete your backup, "Confirm and delete"
  • Go back to the last screen
  • If you have a Samsung phone and are using a Samsung account for backup, turn that off and delete as well
  • Reboot the Phone
  • Sign into the phone and reinstall the Arlo app
  • Launch the Arlo app, sign in, go to settings, notifications, choose your notification tone, back out and then close the Arlo app
  • Go into Android "Settings", then "Cloud and Accounts", then "Backup and restore", turn back on Automatic Restore, your Google back up, and your Samsung backup (if needed)
  • Test your Arlo notification sound, hopefully you only have one sound now
