I have my geofencing home mode to follow the schedule, but when I'm home it shows the system as disarmed. I have it scheduled so during the day my front door camera stays active even when I'm home. But it switches everything to disarmed.
Try using a mobile browser to verify whether it's actually disarmed. Set the browser setting to use the desktop version of the Arlo site. Also, have you tested the system to verify that it's not armed as desired?
Ok, I checked it from the website and I physically walked in front of the cameras that should be recording during the day when the geofencing is in home mode and the cameras are disarmed.
Did you also check the GF and mode settings while using the browser?
You may want to remove the settings and set up again to see if that helps.
