Geofencing doesn’t work when I return home
Has anyone else experienced this?
Peterp416,
Consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Log in to your Arlo Account (the primary) and navigate to Mode > select your Arlo system > edit Geofencing > click "Enabled devices". Toggle all of the listed devices off and save. After you have finished saving, navigate back to "Enabled devices" and toggle all desired devices back on and save.
Thanks very much. Interesting, now that I've done that instead of "out of zone," my iPhone has a grey "unavailable." I tried restarting the app, and doing the process again, no change. I changed the mode to geofencing (from disarmed that I had manually set because the geofencing wasn't working) and now it seems to pick it up properly as "in zone." I'll monitor this to see if the problem comes up again.
