  • 1 Reply
  • 2333 Views
r1wheel
Hi,
Cant seem to get geofencing to function correctly.
Using one enabled device - Iphone 7, Iphone settings - Alro location = always, background refresh = on.
Geofence settings
Away mode = Armed
Home mode = Disarmed
Radius set = Large
When im home i get notification "You have entered the Home Zone", when i leave the zone i get "You have left the home zone" so clearly the app knows my location, the map within the app shows im inside/outside the zone, when i enter the "Enabled devices" tab in the app, Iphone = In zone or out zone.
However, the Alro unit is always stuck in the away function(armed). Under "My devices" i can see, Alro Camera = Armed. I can come in and out of the home zone but the device always seem to set the away (armed)function.
Is there something im missing?
Geofencing is designed to operate on a "first in, last out basis". This means that if any device is in the Geofencing radius the "Home" mode will enable, and the "Away" mode should only enable when the last device has left the radius.
How does the first in, last out principal work with geofencing mode for my Arlo cameras?
For this to work be sure the app stays logged in, is running and location is enabled on your devices. If the app is logged off/not running Geofencing will not work.
When using multiple devices, the secondary devices should be logged into the app via shared account through the "Grant Access" feature so that both devices are logged in using the mobile app. Take a look at this article for more information: How do I add and manage multiple mobile devices for geofencing?
If you are having trouble with this, consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Log in to your Arlo Account (the primary) and navigate to Mode > select your Arlo system > edit Geofencing > click "Enabled devices". Toggle all of the listed devices off and save. After you have finished saving, navigate back to "Enabled devices" and toggle all desired devices back on and save.
