Geofence stuck in home mode Potential Fix
I have been having troubles with geofence reverting to home mode intermittenlty while I was away. The last two days geofence has been stuck in home mode. I tried swithcing between modes which often helps but this has not worked for these two days. I restarted the base and checked for updates for the base and app, none found.
I finally figured out a work around: I changed the radius . Should not have to do this.
0 REPLIES 0
