For those of you who have had your Pro systems up and running for a while, can you share with me how freuqently you try to connect to a camera and get a connection failure.
I'm finding that I get these random failures several times a day, and not specific to any of the four cameras I have.
So far I've been able to try a variety of techniques to get the camera to "wake up" and connect to the base:
1) Toggle the on/off switch under devices
2) Keep hitting the "go live" button until it connects
3) Switch from my Iphone to my Mac
4) Shut down the application and start it up again.
Eventually, some combination of the above four techniques seems to wake the camera up and establish a connection, but it's quite frustrating.
I'm on the latest version of firmware for the cameras and base. Iphone 7 Plus on latest version of iOS. All cameras showing 3 bars signal strength to base.
I also notice that push to talk will not work on my Mac using safari, but switching to Firefox works fine. Is this a known problem as well?
I have two that have never gone offline. What is the WiFi signal showing for your cameras? How close are they to the base? Are there any 2.4GHz wireless devices near the base? Have you tried both the app and a browser? For the app, have you tried both cell service as well as WiFi?
I do have a dual band router about three feet away. I've moved it as far away as practical to minimize interference but I don't really have any other place to put it. Is 2.4 Ghz interference a definite issue for these units?
There is no consistency on which cameras will fail. All of them do on occasion but eventually come back online after fiddling with the software.
Sorry ,can't help... my PRO has been rock solid
I disabled the 2.4Ghz frequency on my router, so that it now only supports 5Ghz. I'm not sure what devices may break as a result of this, but I'll keep an eye on the camera connections to see if this improves reliability and report back.
So far I've had two failures to connect since disabling the 2.4Ghz band on my router. And my nest thermostat stopped working. Apparently 2nd gen Nest only supports 2.4Ghz, while 3rd Gen supports both bands. I was able to reconnect the Nest to an alternate access point on the second floor, so no big deal.
But it appears that the connection failures are not exclusively related to 2.4Ghz interference.
Any other suggestions for troubleshooting this?
