Format USB Device does nothing: VMB4000r3 . Latest firmware installed.
Firmware 1.20.4.1_4214_d606780
Hardware VMB4000r3
USB Device Seagate Backup Plus Slim 2TB Portable External Hard Drive with 200GB of Cloud Storage & Mobile Device Backup USB 3.0Mobile Device Backup USB 3.0 (STDR
Format USB Device for local storage does nothing. Is Seagate incompatible?
On a computer, check for multiple partitions. If there's more than one, remove all and then format as FAT32 (the computer may need a 3rd party program to do this). Of course, it may be an issue of the hard drive and the base - note the warning Arlo provides when setting up local storage about hard drives.
Also, a thumb drive is much easier to work with than a hard drive. a 32-64GB drive will hold an awful lot of videos.
